Merging / Blending not Catching ...
Frank1000
Skype: the2he
Post by Frank1000 » 29 Oct 2012, 03:19
I'm trying to blend or merge the two halfs of the glasses frame together, but nothing happens when I select both, hit model > create > Poly.Mesh . Blend / or merge and tweak the tolerance ...
Any hints what's going wrong ?
Regards,
Frank
Re: Merging / Blending not Catching ...
Post by Hirazi Blue » 29 Oct 2012, 07:57
Can't tell exactly from your screenshot, but it could be that there are no "boundary edges" ("holes").
Try deleting the polygons facing each other on each half and try again...
SreckoM
Skype: srecko.micic
Post by SreckoM » 29 Oct 2012, 09:54
Reverse normals on one of them?
- H -
Frank1000
Skype: the2he
Post by Frank1000 » 29 Oct 2012, 11:30
ah ok, needs to be open edges. In the doc it showed closed polymeshes.
Now I use welding because it is one object that I have Symmetrized Poligons.
Image [/img]
Unfortunately it splits back open again when I edit the underlying curve.
Post by rray » 29 Oct 2012, 14:18
This changes the topology and with it the position of the deleted polygon. Best approach is to do all topology adjustments before adding the delete operator.
