Overriding materials set by ICE Topology
gustavoeb
Skype: gustavoboehs
Post by gustavoeb » 22 Oct 2012, 23:30
So, apparently this is not as simple as applying a material to my partition... any ideas? Is it even possible?
Gustavo Eggert Boehs
julian johnson
Re: Overriding materials set by ICE Topology
Post by julian johnson » 24 Oct 2012, 09:00
I put a custom boolean parameter on the relevant object and override this boolean as necessary with a conventional override. The boolean is then used in the ICE tree where you set materials to either only use MaterialID 0 or use the other MaterialIDs. If you set it to only use MaterialID 0 then the 'normal' material applied to the partition will be used...effectively allowing you to override ICE-generated materials. Hope that makes sense..
gustavoeb
Skype: gustavoboehs
Post by gustavoeb » 24 Oct 2012, 11:51
Thanks, sounds very doable...
