Hail to thee,
Perhaps this has been brought up before, but I find myself at odds with the lack of quality in the Softimage viewport when viewing a scene that has objects placed out in the 11,000 unit range. I am building a large city for a game and it must be to scale, but working from a distance is hard because of the constant flickering and depth issues. Select triangles from objects hundreds of units behind another start appearing in front. This creates a garbled mess of triangles and black backfaces. Judging the overall shape and composition from a distance is critical for a game city, but this cannot be done. I have tried different modes, but there is no real difference aside from a huge FPS drop. After using 3DS Max and Maya, I greatly admire Softimage, and this is the first real issue I have with it.
Does anyone know how to improve the viewport quality at huge scales?
Any help is greatly appreciated, thank you.
Viewport Quality Horrible with Large Scale Scene
SvalinnAsgard
csaez
- Skype: csaezmargotta
Re: Viewport Quality Horrible with Large Scale Scene
Play a little bit with the clipping planes of your camera, lowering the near plane should do the trick ;)
SvalinnAsgard
Thank you for the reply. Your suggestion appears to have worked quite well; I had sent my far clip plane very far away early on and the range between the two was in the millions of units, causing a lot of distortion.
Thanks again.
Thanks again.
