Hi there,
Just wondering if anyone knows if it's possible to select faces based on vertex colour?
Pete
is it possible to select faces base on vertex colour?
Pete
Re: is it possible to select faces base on vertex colour?
I believe you can however, the vertex color actually colors samples (usually 4 samples per vertex if the mesh is all quads, more or less with irregular geo). You'll have to get the average and if its above / below a certain tolerance then you'll have to add that vertex index to a list. Then after you iterate over all the vertices clear the selection and add the vertices from that list to the selection.
Pete
Thanks Eric, but I think that sounds a little above my level. I'm not really even sure how to select a sample through scripting
iamVFX
Like so: http://procedural.tumblr.com/post/10642106975Pete wrote:I'm not really even sure how to select a sample through scripting
Well the sample is different than a point / vertex but the method iamVFX posted will get you close you just have to change the selection filter I believe.
Anywho, I dug up an old script that you can pick apart and tinker with to get you started:
# Python
from win32com.client import constants as c
from win32com.client import Dispatch as d
xsi = Application
log = xsi.LogMessage
collSel = xsi.Selection
DEBUG = 0
def runMe():
oPickVertexMap = xsi.PickElement(c.siPropertyFilter, "Pick Vertex Map", "Pick Vertex Map")
if oPickVertexMap("ButtonPressed") == 0:
log("Command Cancelled", 4)
return False
oVertexMap = oPickVertexMap("PickedElement")
if oVertexMap.Type != "vertexcolor":
log("Picked Object is not a vertex color map. Command Cancelled.", 4)
return False
xsi.FreezeModeling(oVertexMap)
oPickTgtPolys = xsi.PickElement(c.siPolygonFilter, "Pick Target Polygons", "Pick Target Polygons")
if oPickTgtPolys("ButtonPressed") == 0:
log("Command Cancelled",4)
return False
lTgtPolys = list(oPickTgtPolys("PickedElement").SubComponent.ElementArray)
aVertexColors = list(oVertexMap.Elements.Array)
collFacets = oVertexMap.Parent3DObject.ActivePrimitive.Geometry.Facets
lFacets = [x for x in collFacets if list(x.SubComponent.ElementArray)[0] in lTgtPolys]
for eachFacet in lFacets:
lSamples = list(eachFacet.Samples.IndexArray)
for intSampleIndex in lSamples:
sRed = aVertexColors[0][intSampleIndex]
sBlue = aVertexColors[1][intSampleIndex]
sGreen = aVertexColors[2][intSampleIndex]
log(str(sRed) + "," + str(sBlue) + "," + str(sGreen))
runMe()
Pete
Hey thanks guys,
I'll see what I can do! I've never used python before but i'll see how i go.
Pete
Pete
Lots of good resources out there for learning Python. Probably should compile a list and post it as a sticky thread. The main thing is actually learning the Softimage Object Model and then you can hack together small tools to speed up your normal workflow.
Good luck and post back your progress. Will help to share with others and this is a good place to ask for some help.
Pete
Will do! Hopefully I get something going
I can't guarantee this still works, but the "Vertex Color Tools" by Andrea Padovan (available still in the local backup at rray.de, even with a x64 version) sports a "Color to Selection" option, that might be useful in this case, as it gives the option to convert to a sample/point/edge/polygon selection. Specify Color and acceptable deviation, select what kind of components you want to select and press select.
Boo! Spoil the learning why don't you!
Pete
Ha, thanks guys!
That add on is doing the job so it's kinda crushing my will to learn the python way
I did manage to get it to take notice of the samples that were within an alpha range I was looking for.
