Hello all.
When I generate 3D Point grid each frame in Simulation stack, it increments its position on Z axis each frame. Why?
Thank You.
Generate 3D Point grid strange behaviour
iamVFX
Re: Generate 3D Point grid strange behaviour
Because the compound works with array of points which are created and moved by "Set Point Position" each frame. Use "Filter if Emitted" compound if you want to create simulated point cloud once.
Mr.Core
- Skype: giga-core
The problem is that "generate 3D Grid compound" uses pointID for placing points on the axes, so the solution is simply - place the modulo by count of generated points on branch where Z-placement happens to ignore previous generated points ( which perform this weird offset )
Victorcg
Thank You for help. I've used he second one. It works!
