how Constraint Nulll to point
Boris
Post by Boris » 03 Oct 2012, 17:28
Hello there ! i have a little question , how constraint a null to a point on the surface, so that when we drag point the null is also moving and vice versa !?
Oops ,something went wrong :D
Kerro Perro
Re: how Constraint Nulll to point
Post by Kerro Perro » 03 Oct 2012, 18:26
Right click > create cluster with center
Boris
Post by Boris » 03 Oct 2012, 19:15
Kerro Perro wrote:Right click > create cluster with center
Thank you for reply !
but , it's not enough, I need that the point of surface can control the position of null, and vice versa. when I change face shapes through blend shape all the nulls was left behind forms. how fix it ?
Kerro Perro
Post by Kerro Perro » 03 Oct 2012, 19:32
Whoops yeah i thought that worked - could've sworn i just used that simple method on a face once... but i seems it doesn't #-o
Anyway this script works to constrain the null so it moves when you shape animate it - Use the "null to point" option http://xsisupport.com/2012/03/13/oo-add ... in-python/
But then the null the won't move the point - off the top of my head i don't know how to make it do both :ymblushing:
Boris
Post by Boris » 03 Oct 2012, 20:14
Kerro Perro wrote:Whoops yeah i thought that worked - could've sworn i just used that simple method on a face once... but i seems it doesn't #-o
nevertheless thanks for the help! :ympeace:
grahamef
Post by grahamef » 03 Oct 2012, 20:17
You can't do both -- that would be a bidirectional constraint and it isn't supported. It would create a dependency cycle. So you can have one (Object to Cluster constraint) or the other (Cluster Center deform) but not both.
Kerro Perro
Post by Kerro Perro » 03 Oct 2012, 20:18
Ah good i feel less stupid and lazy now ;)
Boris
Post by Boris » 03 Oct 2012, 20:48
Thank you guys for your active participation in the solution my problem! :| :)
Ahmidou
Post by Ahmidou » 03 Oct 2012, 21:32
Boris
Post by Boris » 03 Oct 2012, 22:03
Ahmidou wrote:You ca try this:
http://www.softimageblog.com/archives/209
Thank you very much ! it's very very useful ! :-bd :)
Post by EricTRocks » 25 Nov 2012, 21:58
Select the Vertex > Create Cluster. Select the Null > Constrain > Object to Cluster. Done. No need for scripts.
Eric Thivierge
