Duplicate Edge loops with Even spacing
Falam
The two edge loops have 3.42m spacing which is circled in the image. I want to duplicate those edge loops evenly with a 9m distance apart, all the while keeping 3.42m spacing between the edge loops as they are duplicated. How can I accomplish this ?
dwigfor
Re: Duplicate Edge loops with Even spacing
Assuming you aren't creating a crazy amount of loops, I would create a grid sized to your 9m, add your edge loops, and then snap them to the grid. Move the grid down, and snap the next edge loop. Maybe there's an easier method, but you'll spend more time thinking about it than just doing this...
I would just get rid of all mesh except the module then duplicate and move the module to the distance you wish and then bridge/merge.
myara
I know I'm late, but you could do it with Knife (Slice Polygons), and set a number of Slices.
Set Custom Plane and specify your center position.
M.Yara
Falam
These are the problems with the slice tool, is there not a tool that fixes the slice tools flaws ? The custom plane tool only gives a little more flexibility. The snapping method is as tedious as using the slice tool to do the job, I want to save time not break even with time.
