Objects or object references fed into arrays
forsgren
Hi! The idea is to have a group of objects, torus, torus1 torus2 ... , feeding them into a array, getting them back from the array and to cool stuff with them in a while-loop. The problem is I can't get the objects, the objects names or their references into the array compound unless I convert them into strings. The problem then is there is no string-to-reference-node. I know i've probably messed up somewhere cause there has to be a way to handle multiple objects inside arrays...right?
csaez
- Skype: csaezmargotta
Re: Objects or object references fed into arrays
AFAIK the only way to get an array of valid object in ICE is via groups.
forsgren
Ok... Is there anyway to recall them with some kind of group id, or store the group with set data?
CiaranM
What are you trying to do exactly? If you want to deform points for example, you can only deform the points of a single object at a time (the object the ICE tree is living on). You can't run a single ICE tree over all members of a group simultaneously. The workaround might be to merge all group members into a new mesh using ICE topology. Then you can figure out the group ID of each input mesh and deform each group member differently.
