Hi all.
This might be the simpliest thing ever but I just can't figure it out at the moment. What I need to do is tie one end of a linear line to a null and the other end to another null which is constrained to a path so this end is moving constantly.
I've had some progression with ICE but for some reason the line ends are not exactly on the nulls. There a slight offset on both ends but still it follows the constrained nulls path.
So any ideas are very welcome.
Constraining ends of a line
Re: Constraining ends of a line
You can do this in old fashion way, select point on curve, RMB > create cluster with center. It creates null and operator automatically. Just be sure it's linear curve, so there's only two points on it.
bdamien
Yes! So simple, yet I was so far away:) Thanks a lot!
