Hardness / Flatness from Weight Map ?
Falam
Post by Falam » 19 Sep 2012, 21:54
I came up with an idea. Using weight maps you can adjust the level of hardness / flatness the surface has regardless if it's flat or curved all from weight maps.
Letterbox
Re: Hardness / Flatness from Weight Map ?
Post by Letterbox » 20 Sep 2012, 19:25
Falam wrote:I came up with an idea. Using weight maps you can adjust the level of hardness / flatness the surface has regardless if it's flat or curved all from weight maps.
which could be connected to a sub-d object.
Falam
Post by Falam » 20 Sep 2012, 23:25
Sorry, I don't follow ?
