Selecting according crease angle value
benoit81
Post by benoit81 » 17 Sep 2012, 09:38
Hello,
Is there any way to select edges according to crease angle values ? Would be nice to mark hard edges automatically.
Thank you
gaboraa
Re: Selecting according crease angle value
Post by gaboraa » 17 Sep 2012, 10:49
under the selection filters>crease edges. With it, you can select all creased edges using select all command (ctrl+a)
benoit81
Post by benoit81 » 17 Sep 2012, 12:07
Thank you Gaboraa,
Unfortunately, it's not the tool I'm searching for. It's not about subdivision surfaces. It's more simple : when you define a discontinuity angle in polymesh (geometry approximation), I would like to be able to select the angle above this value (in order to mark hard edges, or anything else...).
Regards,
Post by rray » 17 Sep 2012, 13:35
The old rctools has a function for this. See http://rray.de/xsi/rctools/ (2013 only)
Use "open custom filter ppg" then go to edge tab, uncheck everything except "sharp edges...apply", click "select all" in top row.
benoit81
Post by benoit81 » 18 Sep 2012, 09:33
Thank you, RC Tools is great :-) It's exactly what I was searching for.
Regards,
Post by Hirazi Blue » 18 Sep 2012, 10:12
rray wrote:The old rctools has a function for this.
I wouldn't start calling the rctools "old", I'd call them "venerable".
They might have been created in the Dark Ages, but they still serve their purpose quite well.
And in the end that's all that counts IMHO ;)
