Maya BonusTools 2013 - UV Tools
gaboraa
Post by gaboraa » 13 Sep 2012, 14:51
iamVFX
Re: Maya BonusTools 2013 - UV Tools
Post by iamVFX » 13 Sep 2012, 15:37
Pff, XSI has Unfold3D since version 7.5
Bellsey
Post by Bellsey » 13 Sep 2012, 19:52
actually Maya got its UV unwrap in Maya 2008, this just an auto version of the same thing.
benoit81
Post by benoit81 » 14 Sep 2012, 06:56
Maya UV Tools seems to be much more flexible : you can unwrap (uniqueUVs) or apply projection to several objects, or unwrap a selection of faces. It would be very nice if Softimage can do it... I do not understand why subprojection do not include uniqueUV and unfold, it's bad for workflow, IMOHO.
gaboraa
Post by gaboraa » 14 Sep 2012, 10:41
At least they continually develop some UV tools and they may be integrated into Maya someday.
Sil3
Post by Sil3 » 14 Sep 2012, 16:50
You mean the crippled version of what Unfold3d had to offer at the time? Might as well saved the hassle of implementing it... specially since free Blender did much more and majority of us already used Headus UV Layout that was and still is light years ahead of whats implemented today in Soft as UV unwrap tools.
iamVFX
Post by iamVFX » 15 Sep 2012, 14:34
idk what you guys complain about, softimage is a big particle plugin for maya, why would autodesk programmers waste their time making same features for all packages?
Post by Hirazi Blue » 15 Sep 2012, 17:51
Unfold3D was in itself a nice bonus tool (nothing more, nothing less) to a release I mainly recall as a quick way to roll out Autodesk licensing. I don't think Unfold3D was ever intended as real full-fledged competition to any external solution...
Post by EricTRocks » 16 Sep 2012, 01:13
I'd rather have it than nothing. It does a decent job for what its features are and the tools in the UV editor provide a decent toolset to get you where you need to go. I'm not saying there doesn't need to be improvements in the UV editor but a lot of people do find it useful. I really do wish they had more of the Unfold3D tools in it though.
Eric Thivierge
pluMmet
Skype: bigcuberight
Post by pluMmet » 16 Sep 2012, 09:52
I'd rather PTex take over the mapping world :p
benoit81
Post by benoit81 » 17 Sep 2012, 09:36
In those video of Maya UVTools, I really like the way it works : whatever your selection is, it still works (you have several objetcs, a selection of polygons...). Softimage used to be very great in workflow but Softimage UVs are getting too old : automatic packing (uniqueUVs) algorithm is not as good as 3ds max, and you can not apply UVs on multiple objects. The same with the new modeling tools :
- apply thickness can only be done on an object level, not on a mesh selection (not very nice : you have to extract the polygons, apply thickness, merge, and re-apply animations... a nightmare),
- for cap hole, it only works with a point selection, and can not apply several cap in one command,
- apply slice between two vertices is powerfull, but not intuitive IMOO (3ds max slice is much easier).
About Ptex : does it work for realtime 3D too ?
Post by Maximus » 17 Sep 2012, 18:12
For capping i use this script which works with multiple selections.
If you have a hole select all the edge borders and run the script in VBScript
DuplicateMeshComponent
ApplyTopoOp "Collapse"
SelectGeometryComponents ".pnt[LAST]"
ApplyTopoOp "DissolveClean"
Not sure what you mean about the thickness on object selection and not on mesh? I use couple addon for thickness that works pretty well.
Once installed you'll find them in Modeling menù > Modify > Poly.Mesh
iamVFX
Post by iamVFX » 20 Sep 2012, 08:29
Where you guys saw the texturing capabilities of Softimage? :D (sorry, couldn't resist)
[rimg=540]http://xsisupport.files.wordpress.com/2012/09/suite-singlestepinteroperability.png[/rimg]
gaboraa
Post by gaboraa » 20 Sep 2012, 12:09
iamVFX wrote:Where you guys saw the texturing capabilities of Softimage? :D (sorry, couldn't resist)
I HATE that image :))
iamVFX
Post by iamVFX » 20 Sep 2012, 12:26
gaboraa wrote:I HATE that image :))
Sorry, again :D I like it, I love the truth and honesty
Letterbox
Post by Letterbox » 20 Sep 2012, 19:15
I just want to UNFOLD3D.com, there is a link to the xsi plugin which takes you off to "softimage.com" and you end up at Autodesk.
So did Autodesk buy it out?
Will Autodesk do the updates?
Will Unfold3d do them?
Will it get updated?
Or is it like the Shave and Haircut, frozen in time???
