Create Copies From Polygon Mesh
mixepix
Post by mixepix » 13 Sep 2012, 10:34
Hi all!
I've got some issues with the "Create Copies from Polygon Mesh"-node when I'm using it with a pointcloud. If I delete any particles in the pointcloud everything gets messed up. The only solution I've found so far is to copy the positions to a new pointcloud and then use that one instead but that doesn't feel like a good solution. I've attached a jpg to illustrate what I mean.
cheers
Mikael
http://vimeo.com/mikaelpettersen
Tekano
Re: Create Copies From Polygon Mesh
Post by Tekano » 13 Sep 2012, 11:29
yeah there is some stack ordering issues with ICE topo for sure. its either a refresh thing or a stack problem, not sure of exact details. I would have thought that a jiggle of the ice tree in the stack - ie moving it up or down in the modelling stack - but it doesnt help at all. :/
this seems to be a bug with the create copies from polygon mesh node and the way the particles are generated. 8-x
iamVFX
Post by iamVFX » 13 Sep 2012, 11:30
Behold the power of built-in nodes.
It seems like Create Copies from Polymesh does not account the fact that point can be deleted. So you should filter it on a creation
mixepix
Post by mixepix » 13 Sep 2012, 11:42
Yeah, you are right. Thanks!
iamVFX
Post by iamVFX » 13 Sep 2012, 11:52
[rimg=800]http://img155.imageshack.us/img155/7615/7cd51be32aa147a6b0824d8.png[/rimg]
mixepix
Post by mixepix » 13 Sep 2012, 12:05
When you posted the second image I didn't think it would make that much of a difference but it actually made my compound 20% faster. :-bd
iamVFX
Post by iamVFX » 13 Sep 2012, 12:25
Yea, sorry, this way you deletes points for sure
