I was curious what others thought could be improved with the ICE view.
Some ideas I've got:
* in search, you can't search for fragments of compound names. For instance, searching for "get size" will not locate "get particle size". This can make it hard locating a compound, and I think really frustrating for new users that don't yet know exactly what to search for.
* Displaying data being calculated: I wish there was a way to hover cursor over a connection, maybe press a sticky key, and get a popup window of the data generated. Its a pain to always go thru show values, change to numeric. And then you gotta offset it if theres other values already showing. I still cant figure out how to control those offsets. THANK YOU for being able to hide all show values... That saves a lot of frustration trying to clear those damn little icons.
* Displaying data entered into compounds. I wish there was a way to see the data entered into compound ppg on the node. Similar to how it shows what the vector is of a 3D vector (0,0,0). I wish you could see that on scalar to 3D Vector (show the scalar values out on the node). A lot of times, to make it easier to visually read the ICE trees, if I need to Add 1 to a value, I'll still create a scalar value (1) and connect that into the Add node, rather than just keeping it all on the Add node.
Whatcha think?
Improving the Interactive Creative Environment
