Tool similar to MAX Pro Cutter (SOLVED)
Leandro Oliveira
Post by Leandro Oliveira » 14 Sep 2009, 14:06
Hi guys,
Anybody knows a tool in XSI similar to Max Pro Cutter? See the exemplo in link below:
http://www.cgcookie.com/articles/2009/0 ... ect-part-1
I used de Boolean. I created a cube, and I duplicated it in same place. I added a grid and I deformed it with randomize. With everything freezed, I made a boolean operation in one cube and freezed both. So, I inverted the polygons of the grid and I made other boolean with other cube, but the seam doesn´t fit exact...
Thanks,
Leandro Oliveira
www.leandrooliveira.com
Re: Tool similar to MAX Pro Cutter
Post by Hirazi Blue » 14 Sep 2009, 14:17
Not nearly as sophisticated (as far as I can tell) but you might want to take a look at "Xsi Shatter v4" from motionblur.it ;)
Leandro Oliveira
Post by Leandro Oliveira » 14 Sep 2009, 14:42
Thanks, Hirazi! I´ll download it and make some tests.
Cheers.
Leandro Oliveira
Leandro Oliveira
Post by Leandro Oliveira » 14 Sep 2009, 14:55
Hi Hirazi. I liked it very much, but I´d like something similar to crack seams... The seams generated by the Shatter are planars and regular...
But thanks.
Leandro Oliveira
Leo
Post by Leo » 14 Sep 2009, 15:39
Install the Legacy Netview addon. In there you'll find a shatteringscript that will do exactly what you want.
Leandro Oliveira
Post by Leandro Oliveira » 14 Sep 2009, 16:18
Thanks, Leo! That´s it!
Leandro Oliveira
