do you know how to develop wave generator like this?
ikfk
Post by ikfk » 14 Aug 2012, 06:58
very cool
http://vimeo.com/4697942
how to do that? :D
Re: do you know how to develop wave generator like this?
Post by Rork » 14 Aug 2012, 08:24
call the developer who programmed the plugin?
or learn to program yourself?
edit: http://area.autodesk.com/inhouse/videos ... ass_market
There is an ICE compound that does wavecurls, but not as advanced as this.
iamVFX
Post by iamVFX » 14 Aug 2012, 08:29
Rork wrote:or learn to program yourself?
You found an answer to all possible questions related to computer software :D
ikfk
Post by ikfk » 14 Aug 2012, 08:37
want to learn howto program it myself 8-|
how to learn this kind of develop skill b-( thanks
caledonian_tartan
Post by caledonian_tartan » 14 Aug 2012, 08:42
i already deared to ask the Author if i could get and use his plugin.
unfortunately i did not get any answer.
man i wish i could put my hands on this...
SI 2015 @ WIN7-64
Pooby
Post by Pooby » 14 Aug 2012, 08:46
Can you Use ICE?
The basis of this effect is relatively simple to achieve with the "reinterpret location to new geometry" node and getting closest location,
Post by Rork » 14 Aug 2012, 08:52
@ iamVFX: sometimes it's the only proper answer to a question. ;)
People see these amazing effects in commercials or movies, read it's done with software X, and expect to do it them self too in two weeks with the off the shelf version.
They don't realize most of the time it's done by expanding on the available toolset by skilled programmers, or creating completely new toolss by using the SDK of the app.
With ICE this has become more accessible to people, but for more custom effects programming is still needed.
The software ca never anticipate all wishes or idiotic ideas producers come up with ;)
@caledonian_tartan: most of this stuff is done for that particular project and will stay "In house". There's not much companies making the tools freely available after a project. It's also a way to protect their code.
@ Pooby: new vimeo tutorial??? wink wink.... :ymdaydream:
ikfk
Post by ikfk » 14 Aug 2012, 09:06
howto get started? maybe from a book ? or some example like this :D
CiaranM
Post by CiaranM » 14 Aug 2012, 09:09
the basic ocean effect is created with a Tessendorf wave deformer. Have you tried using Amaan Akram's aaOcean Suite? Further deformation can be achieved with basic deformers in Softimage.
Which part of the effect are you referring to?
Post by Rork » 14 Aug 2012, 09:12
how to get started with what? Programming? ICE?
Both have a lot of examples in the manual and SDK manual.
For ICE have a look at the demoscenes in Softimage.
Also, there's a expanding set of videos on Vimeo (Pooby's videos are a really good start here) and Youtube.
More and more ICE related training can be found on websites like CMIVFX, DigitalTutors and so on.
Lot's to watch and read.
ikfk
Post by ikfk » 14 Aug 2012, 09:14
the interactive huge wave :D
Post by Rork » 14 Aug 2012, 09:23
If you watched the video, Florian states it's a mix of lattices and scripted operators.
So, again, learn to program ;-)
People have offered some tips on this in the previous comments. Have a look at ICE, the example scenes and start reading the SDK manual.
Good luck and show us your progress.
CiaranM
Post by CiaranM » 14 Aug 2012, 09:24
ikfk wrote:the interactive huge wave :D
When this video first came out (it was made pre-ICE), it was stated on a few forums that the big waves were shaped using standard Softimage deformers. They probably just had a fancy front end to the tools. The real genius is in the Tessendorf wave deformer. Hats off to Mr. Gebhardt.
CiaranM
Post by CiaranM » 14 Aug 2012, 09:25
Rork wrote: So, again, learn to program ;-)
No need. The tools are publicly available. aaOcean + lattices = win
ikfk
Post by ikfk » 14 Aug 2012, 09:28
thanks for all you :ymhug: :ymhug:
Butachan
Post by Butachan » 14 Aug 2012, 17:59
Allow me to disagree to certain degree with the previous posts, and give you a couple of recommendation you may find usefull. From what you mention you seem to be relatively new to scripting and ice so I will write having that in mind.
Effectively, as was previously mentioned, the author claims that: "lattices and scripted operators (connecting the lattices)" was the base for the tool. He actually specifically said that they took a more artistic approach rather than a programing approach wich as he correctly states would have meant a lot more math calculations to correctly place the points.
Having that in mind: learning to program will not be the best path to take in order to learn "how to create this" But learning to script, that's another story. Scripting is very usefull to create this kind of tools in which you combine and control the effect of different deformers, but scripting is not C++. But be happy about that because is a lot more easy to script than to program. You can find a lot of examples in the web and even a manual on scripting with python for XSI ( what softimage used to be called). As for ICE I will try some tutorials to get the basics and then jump straight into a complex scene and try to figure out how they did it.
Having said that, let me clarify that I am not saying you should not or could not do this by programming (c++) just that it will probably be more easy to do it like they did in the studio (combining existing tools and linking them with scripted operators) A very nice job.
