Copy Animation
Boris
Copy Animation
Post by Boris » 08 Aug 2012, 15:27
Guys this is me again! sorry for bothering but i need your help again!
today i bumped with Shift + ctrl, I can not copy and paste the values ​​Marked parameter! how it fix?
xsi = Application
sel = xsi.Selection
ks = xsi.GetKeyboardState()
def copyAnim(oControls):
	source = oControls[0]
	target = oControls[1]
	mode = ''
	#Shift
	if ks(1) == 1:
		mode = 'siTranslationParam'
	#Ctrl
	elif ks(1) == 2:
		mode = 'siRotationParam'
	#Shift+Ctrl
	elif ks(1) == 3:
		mode = 'siMarkedParam'
	#Ctrl+Alt
	elif ks(1) == 6:
		mode = 'siScalingParam'
	#Default
	else:
		mode = 'siTransformParam'
	xsi.CopyAllAnimation2(source, "siFCurveSource", mode)
	xsi.PasteAllAnimation(target)
def returnPair(oControls, id):
	half = oControls.Count/2
	firstCtrl = oControls(id)
	secondCtrl = oControls(id+half)
	pair = [firstCtrl, secondCtrl]
	return pair
def matchControls(oControls):
	a = oControls.Count/2
	for id in range (0, a):
		ctrls = returnPair(oControls, id)
		copyAnim(ctrls)
#Alt menu
if ks(1) == 4:
	XSIUIToolkit.MsgBox( '''=============================================
Notes about this tool:
pmCopyAnim simplifies the process of copy/pasting animation from one object to another
What this tool does:
Running this script while having an even number of items selected will split the list halfway and copy the animation from the first object of the first half to the first object of the second half, the 2nd object with the 2nd object, etc.
Instructions:
Select an even number of objects
Run the script:
Default:		Copy all transforms
Shift:		Copy translation
Ctrl:		Copy rotation
Alt+Ctrl:		Copy scaling
Shift+Ctrl:		Copy marked parameters
''', 0, "pmCopyAnim Info" )
else:
	if sel.Count%2 ==0:
		matchControls(sel)
	else:
		#Error message
		XSIUIToolkit.MsgBox('You need to select an even number of controllers', 0, 'ERROR')
:ymhug:
Thank you for feedback ! :ympeace:
Oops ,something went wrong :D
