Boris
Post
by Boris » 08 Aug 2012, 12:01
Hello Guys ! Yesterday I have found a script for animation and it doesn't work , who can help to fix it? i have received an error # ERROR : invalid syntax - [line 24] -- if fc.GetMinKeyFrame() maxFrame:
from win32com.client import Dispatch as d
xsi = Application
ks = xsi.GetKeyboardState()
def getCollections(item):
for param in item.Kinematics.Local.Parameters:
if param.Keyable:
collParams.AddItems(param)
if param.Source:
collFCurves.AddItems(param.Source)
for property in item.Properties:
if property.Type == "customparamset":
for param in property.Parameters:
if param.Keyable:
if param.Source:
def getMinFrame(collFCurves, current):
minFrame = current
for fc in collFCurves:
maxFrame = fc.GetMaxKeyFrame()
return maxFrame
# Execute
if ks(1) != 4:
collParams = d( "XSI.Collection" )
collFCurves = d( "XSI.Collection" )
current = xsi.GetValue("PlayControl.Current")
sel = tuple(xsi.Selection)
for item in sel:
# Move Left 1 frame
if ks(1) == 2:
offset = -1
startFrame = getMinFrame(collFCurves, current)
endFrame = current
# Move Left Input frames
elif ks(1) == 3:
offset = -1*float(xsi.XSIInputBox("Number of frames?", "Negative Offset", "3"))
endFrame = current
# Move Right Input frames
elif ks(1) == 1:
offset = float(xsi.XSIInputBox("Number of frames?", "Positive Offset", "3"))
startFrame = current
endFrame = getMaxFrame(collFCurves, current)
# Move Right 1 frame
else:
offset = 1
params = collParams.GetAsText()
xsi.ScaleAndOffset(params, "siInputParameters", offset, "", startFrame, endFrame, 0, False, "siFCurvesAnimationSources", True, "", False)
# Alt Menu
else:
XSIUIToolkit.MsgBox( '''=============================================
Notes about this tool:
pmOffsetKeys allows you to quickly move the keys in one direction or another using the current frame as a starting point
Instructions:
Select your animated objects
Run the script:
Default: Offset by 1 frame to the right
Crtl: Offset by 1 frame to the left
Shift: User input offset to the right
Shift+Ctrl: User input offset to the left
''', 0, "pmOffsetKeys Info" )
Oops ,something went wrong
Post
by Hirazi Blue » 08 Aug 2012, 14:01
Don't know if that's the root of the problem, but there is something missing in this line
The "if" statements expects an condition, but there is no operator (like "==","<", ">" or maybe "in"???)
between the "fc.GetMinKeyFrame()" and "maxFrame".
BTW: using our special CODE tags makes posts with code somewhat easier to read...
Post
by rray » 08 Aug 2012, 14:27
It looks like there's a whole block of code missing. There's probably a "<" and a ">" in there which the code parser of the website where this was copied from (
http://philmelancon.wordpress.com/) interpreted as a tag ... my best guess is:
minFrame = current
if fc.GetMinKeyFrame() < minFrame:
minFrame = fc.GetMinKeyFrame()
return minFrame
def getMaxFrame(collFCurves, current):
maxFrame = current
if fc.GetMaxKeyFrame() > maxFrame:
return maxFrame
Boris
Post
by Boris » 08 Aug 2012, 14:54
rray wrote:It looks like there's a whole block of code missing. There's probably a "<" and a ">" in there which the code parser of the website where this was copied from (
minFrame = current
return minFrame
maxFrame = current
return maxFrame
oh my god
Now I know where I have seen it . Thank you Guys for participation!
thecook
Post
by thecook » 05 Jan 2015, 19:17
hey guys
finding this script, i wonder if there is some other scripts where i can give an individual offset on each selected object.
eg,
obj_1 starts frame 1
obj_2 starts frame 10
obj_3 starts frame 20
for a start i found this on the as usual brilliant caffein abuse:
http://caffeineabuse.blogspot.ch/2008/1 ... -time.html
but this works with expressions.
i need to "physically" offset my srt fcurves on 2500 objects...
anyone has a help here?
Post
by Hirazi Blue » 05 Jan 2015, 23:07
Is there a specific reason why you don't want to use a similar method to the one caffeinabuse describes?
thecook
Post
by thecook » 05 Jan 2015, 23:16
Hirazi Blue wrote:Is there a specific reason why you don't want to use a similar method to the one caffeinabuse describes?
cause i do have fcurves already on all objects.
now i need to offset them.
and
this is the script that does it:
http://www.xsiforum.de/thread.php?threa ... ion+offset
i think rather handy.
thanks to PPanther and Helli.
mantom
Post
by mantom » 07 Jan 2015, 00:23
Why don't you use the HLE mode in the animation editor and offset your FCurves in bulk?
You can also put all your FCurves into mixer source(s) and apply offset map(s).
thecook
Post
by thecook » 07 Jan 2015, 10:09
guys, i probably did not explain this properly.
this is what i'm talking.
i know how to offset fcurves manually.
and now this script applies it on my 1500 animated objects.
i use this alot for MoGraph an stuff.
