I need to blend different shaders one on top of each other, creating complex effects and texturing, the problem is i've noticed both mr and vray in 3ds max have the ability to use the blending mode with a fresnel fallof, based on index of refraction, which makes the shading be physically correct related to the IOR and the actual material you are creating.
Now i've banged my head on the wall for the past 2 hours tryin to replicate this thing inside Softimage without any success. Here is the thing, to do the fresnel effect i would use the Incidence node, but this node has nothing to do and its not driven by the index of refraction, its more "artistic" oriented tool, you move the sliders and the fresnel effect changes as you like it. But again its not that correct.
So what i thought was.. ok lets see if mental has some IOR node i could use, with my big surprise i typed "index" in the search toolbox in render tree and a mib_refraction_index popped out.
I tried to use this node and set the IOR here to drive the incidence but again i cannot be sure this is the correct way to do so. The results are quite different from the 3ds max "Fresnel" texture at same IOR values.
Here are couple of screens to illustrate what i mean. This is the normal setup in softimage where you have the incidence controlling the blend between the 2 shaders, again this has nothing to do with IOR and the fresnel effect its not controlled by that. The Incidence is set to surface/camera standard.
Here is a screen of 3ds max with the option to drive the fresnel effect based on a IOR.
Basically, how can i have the fresnel effect driven by the IOR in Softimage? This is vital to create some realistic materials to me.
Thanks, Max
