List of all Shaders
TwinSnakes007
List of all Shaders
Is there a way to get a list of all shaders without traversing the RenderTree port by port?
Re: List of all Shaders
Not really. Here's a Python snippet that gets all the shaders in a render tree.TwinSnakes007 wrote:Is there a way to get a list of all shaders without traversing the RenderTree port by port?
TwinSnakes007
For a reference parameter on a shader, all shaders from all material libraries in the current scene are displayed in the picking session, whether the shader is connected to anything or not. Is that list available in the SDK?xsisupport wrote:Not really. Here's a Python snippet that gets all the shaders in a render tree.TwinSnakes007 wrote:Is there a way to get a list of all shaders without traversing the RenderTree port by port?
edit: Thanks for the script.
Can you give me an example of a reference parameter?TwinSnakes007 wrote:For a reference parameter on a shader, all shaders from all material libraries in the current scene are displayed in the picking session, whether the shader is connected to anything or not. Is that list available in the SDK?xsisupport wrote:Not really. Here's a Python snippet that gets all the shaders in a render tree.TwinSnakes007 wrote:Is there a way to get a list of all shaders without traversing the RenderTree port by port?
TwinSnakes007
Steve,
When you set the filter attribute for a shader param:
and then set it's type to siShaderDataTypeReference:
In the PPG for that shader, you'll get a "Pick" button next to the connect icon for that parameter.
paramOptions.SetAttribute( constants.siReferenceFilterAttribute, constants.siShaderReferenceFilter )Code: Select all
params.AddParamDef( "bsdf", constants.siShaderDataTypeReference, paramOptions )-
Ah well, I was hoping to save some time by looking at an existing shader to see the behavior you described.
from sipyutils import si # win32com.client.Dispatch('XSI.Application')
from sipyutils import C # win32com.client.constants
si=si()
sClassID = "{6495C5C1-FD18-474E-9703-AEA66631F7A7}"
x = si.FindObjects( "", sClassID )
TwinSnakes007
Steve,
I'm running to a meeting, but I thought about going the ClassID route too, but I have 30-50 custom shader def's. Wouldnt that mean I'd have to look for each one of them in a separate call?
P.S. I dont know of an existing SI shader, but you can load my shaderdefs here and look at one of them to see how the reference parameter behaves:
https://www.mitsuba-renderer.org/hg/mit ... Shaders.py
TwinSnakes007 wrote:Steve,
si=si()
shaders = si.FindObjects( "", sClassID )
# If your shaderdefs had a common prefix, you could
# filter the XSICollection returend by FindObjects
#shaders.Filter( "", "", "MTS*")
# Using the shaderdef category:
def f(x):
return x.ShaderDef.Category == "Mitsuba/bsdf"
# Get list of shaderdefs x that match the filter f(x)
defs = [x for x in filter( f, shaders ) ]
TwinSnakes007
Thanks for the tip Steve...looking thru the sdk docs, there was an example there the whole time for FindObjects
# Enumerate all shaders under the scene root.
from win32com.client import constants as c
shaders = Application.ActiveSceneRoot.FindObjects( c.siShaderID )
for s in shaders:
LogMessage( s.ProgID )
# INFO : Softimage.soft_light.1.0-
There's also Material.GetAllShaders, which I overlooked
TwinSnakes007
Here's what I ended up with:
from sipyutils import log
app = Application
oMatLib = app.ActiveProject.ActiveScene.MaterialLibraries
for oLib in oMatLib :
log (oLib.Name)
for oMaterial in oLib.Items :
log (oMaterial.Name)
oShaders = oMaterial.GetAllShaders()
for oShader in oShaders:
log (oShader.Name)
