Tim Borgmann und Christian Keller won the "Clio Award Gold 2009" with the "Audi Filter"-Spot. In production they made massive use of SIs ICE system using up to 50 mio particles..
watch the Spot here
take a look on the WINNERS
CONGRATULATIONS..!
oliver
Clio 2009 for "Audi Filter"...
owei
farhaad_yousefi
- Yahoo Messenger: farhaad_yousefi@yahoo.com
Re: Clio 2009 for "Audi Filter"...
will there be any post about how they did it.?!
material..sharers.. .?!
ugh... should learn to look at links in posts.. ;)
Hi Rork, your first link is, as far as I can tell, just the one linked to by owei in the first post in this thread, but on Youtube (in lower quality?) and your second link is the "Making of" that you can find on said page linked by owei. And I think farhaad_yousefi's question was slightly more specific and the answer sadly seems to be: probably not... ;)
mypeople
anyone know how to achieve that chromatic abberation effect they use through the entire commercial?
Deracus
Most easily done in Post-Processing...
The Method for doing this, that i know, is done by splitting the base-image in its three channels.
Then you can offset the channels in different directions and merge the image later on...
The offset-amount can be driven by a gradient so that it becomes stronger to the edges. This simulates the real-error that is caused by the camera-lens, that may offset the different wave-lengths to the borders of the image...
Chromatic Abberation is nothing else than an overlay-error of the three color-channels while recording...
mypeople
hey deracus, do you have an example of how thats driven by a gradient? i'd like to see what you mean.
Don't know, if Deracus means this method, but Ewald showed a way to create chromatic aberration in the FXTree in this thread on XSIBase... ;)
mypeople
exactly what ive always wanted to be able to do, thanks so much guys.
Deracus
Exactly that was, what i meant with it
Forgot, where i read about it so i couldn´t link that in.
Thanks Hirazi for doing so ;)
