Script text to viewport?
Post by Hirazi Blue » 30 Jul 2012, 10:06
I am looking for a way to let my Python script display (as in: write) certain parameter values at more or less arbitrary position within a 3D viewport (let’s say for instance at the center of an object, for instance). Long ago there was a plug-in named xUI, which would have enabled me to do just that, were it not for the sad fact that it was never compiled for x64 (and quietly vanished from the author's website). Now I am looking for some simple solution that allows me to call a (C++ based) plug-in command some text and a little extra info, like where to put the text (and maybe even minimal formatting info), from the wonderful world of Python. I know not nearly enough about C++ and OpenGL to dare contemplating to write such a plug-in myself, so any help is very much appreciated.
:ymhug:
AceMastermind
Re: Script text to viewport?
Post by AceMastermind » 30 Jul 2012, 17:56
Here's the xUI plugin you mentioned in case anyone is looking for it.
Information:
http://web.archive.org/web/200906072044 ... m/xUI.html
Local backup:
xUI.zip
Post by rray » 01 Aug 2012, 15:12
Another "starting point" could be the XGS_Slate plugin (which includes sources). Built for XSI 4.2, just tested, at 1st glance looks like it's still working (compiled with VS Express 2008 in 64 bit)!
Text position settings etc are in the custom preferences.
Post by Hirazi Blue » 01 Aug 2012, 18:45
Thanks, that actually does work and should prove a workable solution for my current task :-bd
I had not looked at XSG_Slate because I could only find a 32-bit version. I assume you did the recompiling yourself? Is such an endeavor very complicated?
Post by rray » 01 Aug 2012, 19:24
Setting up VSExpress for 64bit compiling was pretty complicated but did that years ago already.. took a few hours. http://stackoverflow.com/questions/1865 ... 10-express
Compiling this was a matter of 10-15 minutes, googling missing opengl includes, updating the project paths, and finally fixing a few simple compiling errors that popped up because they used a diffrerent compiler.
AceMastermind
Post by AceMastermind » 01 Aug 2012, 21:57
I stumbled across this on Vimeo which might also be helpful, seems pretty thorough:
Using VS 2010 Express to compile 64bit plugins for Softimage
