Ice elevation rendering
Post by Maximus » 25 Jul 2012, 19:09
Hello, this is pretty much a shot in the dark...
i remember time ago i saw a compound (or was it a ICE compound+render tree combination) which will render out in gradient colors the elevation of the geometry.
for example like this Image
then i want to assign to each color a different shader. Anyone remember which compound it was? i'm tryin to find it but no success atm.
gustavoeb
Skype: gustavoboehs
Re: Ice elevation rendering
Post by gustavoeb » 25 Jul 2012, 20:29
by elevation you mean the point poistion in Y axis?
if so, here is a rough example... I didnt add the colors you talk about, as that is not key to solving the problem. cheers :)
Gustavo Eggert Boehs
Post by Maximus » 25 Jul 2012, 23:33
Thanks for the help Gustavo, i used the Lagoa node which i just tried and worked, looked inside and it does exactly what you did :)
now off to understand how to assign different materials to those areas from the render tree!
thanks!
gustavoeb
Skype: gustavoboehs
Post by gustavoeb » 26 Jul 2012, 00:17
What about connecting the scalar output of the weighmap lookup into a mix2color node?
mattmos
Post by mattmos » 26 Jul 2012, 08:50
Can you not just do this directly in the render tree? No need for ice trees, apply an xy texture projection and give it a grad from top to bottom. use the grad to drive a mix2colours.
Post by rray » 26 Jul 2012, 18:46
For mixing more than 2 materials you can use the gradient mixer (those little color thingys are texturable)
gustavoeb
Skype: gustavoboehs
Post by gustavoeb » 26 Jul 2012, 18:52
mattmos is right... I feel silly 8-}
Post by Maximus » 26 Jul 2012, 20:46
well apparently...that was easy :D
Didnt really think about it!
Thanks everyone, worked perfect!
Post by Daniel Brassard » 26 Jul 2012, 20:56
Learn something every day! I'm thinking loading some DTM/DGM into Softimage and trying this!
Post by Rork » 27 Jul 2012, 06:55
Not sure if it still works, but there's the old Lume Landscape shader that did all this as well.
