memory limit mental ray
jamination
Post by jamination » 23 Jul 2012, 18:53
If this is NOT set (the check box and amount), will mental ray try to use more than is available in the system and crash, or does it use what the system have available.
Phil Harbath
Jamination Productions
julius
Re: memory limit mental ray
Post by julius » 23 Jul 2012, 21:12
As far as I know, MR will crash with too heavy scenes without setting anything to prevent it.
Kzin
Post by Kzin » 24 Jul 2012, 08:26
i dont set this anymore. from my experience, this is not an issue anymore on 64bit systems.
it makes more sense to split you scene in passes or layers when you know the system ram is not enough, otherwise mr starts to cache the data on hd and this will end up in extremely high rendertimes.
