nulls to ice points (orientation) SOLVED
jamination
Post by jamination » 18 Jul 2012, 21:35
I have put a bunch of nulls in a group and I am getting the global positions for those and piping that into an "add point". I am having trouble getting the "y-orientation" of the individual nulls to control the y-rotation of the particles. I thought it should work the same as piping the group>kine.global.pos into the add point (group.kine.local.roty>axis and angle to rotation>orientation), however this is a no go. any suggestions?
I as able to get it to work by saving the nulls in to an array, the using a "get pointid" and a "select in array" to pump the values into the particle orientation.
Phil Harbath
Jamination Productions
Re: nulls to ice points (orientation) SOLVED
Post by Mathaeus » 18 Jul 2012, 22:08
hi,
by the way, group already is array of attributes from members. You can use any attribute, if all members have it. Let's say group of bones will contain the bone length. Global and local transform are common for anything you have in group.
Usually it's something like this:
jamination
Post by jamination » 19 Jul 2012, 00:16
that's the ticket, thanks.
Phil Harbath
