Momentum 3 (demo version)
azurecgi
Post by azurecgi » 12 Jul 2012, 23:46
I am currently evaluating Momentum 3 for a new project but I have come across a problem that I wondered if anyone else has noticed.
When plotting rigid body motion data to RAM the playback lags by a frame! Also, when you initialise the plot function I noticed that the play head jumps forward a frame (for example, play head jumps from frame 1 to frame 2).
Can anyone else confirm this is a problem, at least with the demo version, and if so, is it solved in the full version?
I have emailed Exocortex support, but haven't had a reply as yet.
azurecgi
Re: Momentum 3 (demo version)
Post by azurecgi » 13 Jul 2012, 14:38
I also need to have a Deform Rigid Body in passive mode, following a null until a certain frame.
I looked at example scene 16, the breaking cartwheel, as it seems to be the effect I need, but when you play it through the mesh seems to be a frame or 2 behind the controlling null! This is no good to me, can anyone confirm this is how it works? and if so, is there a workaround?
