Exocortex Species 1.5 Released!
Species 1.5 is now available at Exocortex.com. This is the third major update in six months that adds functionality and further optimizes user work flow.
What is Species?
Exocortex Species simplifies the process of human character creation from designing your character’s unique attributes, integrating sculpting results, to rig creation, even animation. With Species, you will create higher quality animated characters faster and at a lower cost, while avoiding the generic look that often come when purchasing off-the-shelf models. Exocortex Species supports Autodesk Softimage 2010 through 2013 on both Windows and Linux. Floating and node locked licenses are available starting at $299.
Improvements in Species 1.5
Documentation
Expanded Docs to include Installation instructions and more detailed info on many features
New easy to read Google Docs format
New Feature Anim Tools! - A new set of tools to speed up working with our AnimRig
Mirror Pose allows you to mirror the pose of the selected controls to the opposite side of the animation rig
Mirror Select swaps the selected control to the opposite side
Biped MatchFKIK will switch the selected limb from the current FK or IK mode to the opposite while maintaining the same pose.
AnimRig Changes
New preset hand poses!
Hand Follow IK Option
IK Offset controls for Arms and Legs
Hand Anchor control to AnimRig for attaching props and other objects
HeadLookAt Control Option
Align LegIK controls to world
AnimRig Build Changes
AnimRig build option to adding Transform Setups for Fingers
Synoptics
Update synoptics with new controls
Add hand poses to AnimRig Synoptics
Bug Fixes
Left ForearmRoll deformers misaligned
Hide FK arm bones on PropRig by default ( hides IK arm bones when switched to FK)
Bank Param on right foot inverted
AnimRig build cancel button doesn't cancel
Only display Dual Quat option if available
Change preferences to be per user not per addon
Getting Species 1.5
If you are not yet using Exocortex Species, give it a try by downloading the trial from the Exocortex Species product page.
For those already using Exocortex Species, you can download the 1.5 update directly from here.
Join the Species User Community
Get the most out of Exocortex Species by joining our user support and discussion mailing list, and check out our many tutorial videos on our Vimeo group. These are the best places to learn about Species and get the latest news directly from the developers.
Exocortex Species 1.50
angelous4x
Re: Exocortex Species 1.50
Great up date. Love the IK FK switch.
Minor update which fixes an issue with the Python based Scripted Ops becoming corrupted and reporting python isn't installed.
http://exocortex.com/releases/ExocortexSpecies1.5.2.zip
pluMmet
- Skype: bigcuberight
Being unhappy with Autodesk is very mitigated by how cool you Exocortex guys make si
Exocortex Species 1.5.4 is now available!
http://exocortex.com/releases/ExocortexSpecies1.5.4.zip
This release fixes two bugs that were reported over the last week or so:
- Replace Mesh option to transfer Body Type shapes is now working correctly
- Match FKIK utility now matches correctly regardless of key frames and or reference models
- We've also updated all of our Example Scenes with current versions of the rigs
As with all of our releases, please uninstall the previous version of Exocortex Species before
installing this version or you will run into a lot of trouble.
pluMmet
Such a Great plugin, Thanks!
Shredder565
figures. I go to buy it, and it gets discontinued.
is it still available?
i dont think so, i'd like to get it tooShredder565 wrote: 06 May 2019, 13:19 figures. I go to buy it, and it gets discontinued.
In 2016, when Exocortex Momentum & Implosia were made available for free, I inquired with Ben Houston if Species were to be made available for free as well, but he told me then, that this wasn't about to happen...
What you could try, however, is the addon "growrig", which was a precursor to Species (obviously less powerful), which strangely is still available (follow the link on the bottom of this page)
