getting wirecolour from objects and applying it to particles
Pete
Post by Pete » 08 Sep 2009, 03:17
Hi there,
Just wondering if there'd be a way to set a particle's colour to be the same as the wirecolour of an object it is within (or near).
I'm having a bit of trouble working out how to get and set data for this...
Pete
Re: getting wirecolour from objects and applying it to particles
Post by Hirazi Blue » 08 Sep 2009, 09:23
It's actually quite simple (and a little bit strange)
To get the wireframe color of an object the first instinct would be to Get Data from "myobj.display.wirecolor", this results in a Color output, however it gives the wrong result. If you however get the RGB Data separately, i.e.
Get Data - myobj.display.wirecolorr
Get Data - myobj.display.wirecolorb
Get Data - myobj.display.wirecolorg
and plug their results into an RGBA to Color, leaving the A slot empty, obviously, it does work...
A now for the strange bit: if you want to set the color of a wireframe from your ICE Tree you can use a Set Data on the "myobj.display.wirecolor" and feed it Color Data directly... ;)
Pete
Post by Pete » 08 Sep 2009, 09:33
Hehe,
Thanks for that but I'm trying to grab the colour from a number of objects (inside a group) so using get data on a specific object might not work.
Post by Hirazi Blue » 08 Sep 2009, 09:36
So maybe you should have stated that more clearly in your question?
Leo
Post by Leo » 08 Sep 2009, 10:10
Pete wrote:Hehe,
I don't have XSI here right now but if groups have this parameter then you will be able to grab it as an array.
Pete
Post by Pete » 08 Sep 2009, 10:24
Sorry Hirazi, didn't mean to send you down the wrong there mate.
So leo, how would I do that? Sorry, I haven't really messed with arrays much...
Post by Hirazi Blue » 08 Sep 2009, 11:42
No problem of course... ;)
I am very interested in Leo's solution as I have played around with the problem a bit and was unable to come up with a solution of my own... :D
Leo
Post by Leo » 08 Sep 2009, 11:58
very busy right now
Edit:
We basically check the distances between the particles and the objects. Then we use the index (the position within the array) of the lowest distance as a key to select the proper value in the array. The reason that this works is that the array of positions from the group is sorted the same way the array of colors from the group is.
btw. you are right Hirazi it really doesn't work with just the color.... curious...
