Switch cameras
Boris
Switch cameras
Hi guys , tell me how to make the switch button for camera, so the camera switched to the upper left screen !?
Oops ,something went wrong
Re: Switch cameras
Could you please try to explain a little better, what you mean by "the camera switched to the upper left screen"? At the moment this is unclear to me, making it very hard to help...
Boris
Re: Switch cameras
I want to create a camera and attach them to objects and then switch between the cameras and so it was the upper-left viewport / i hope you understand me /Hirazi Blue wrote:Could you please try to explain a little better, what you mean by "the camera switched to the upper left screen"? At the moment this is unclear to me, making it very hard to help...
Re: Switch cameras
So you define two cameras beforehand and want a button to switch between them in the upper-left viewport? A script button like that obviously will have to know which cameras (names) to switch between.
Boris
Re: Switch cameras
Yeah, exactly !Hirazi Blue wrote:So you define two camera beforehand and want a button to switch between them in the upper-left viewport?
Re: Switch cameras
If I find the time, I will look into it over the weekend... (but I can't promise I'll find the time) ;)
Boris
Re: Switch cameras
ok, I hope you can help me, thank you for your attentionHirazi Blue wrote:If I find the time, I will look into it over the weekend... (but I can't promise I'll find the time) ;)
Re: Switch cameras
Try this very quickly made, untested little script. Replace the strings after CameraName1 and CameraName2 with the strings for the actual names of your cameras. Create a toolbar, drag the script unto it, to make a button.
It's Python, by the way. Look out for the tabs (the lines after if and else should be indented by one tab... ;)
For this to work, one of your two camera has to already be selected in Viewport A.
CameraName1 = "Camera"
CameraName2 = "Camera1"
camthis = Application.GetViewCamera(0)
if str(camthis) == str(CameraName1):
Application.SetViewCamera(str(CameraName2), 0)
else:
Application.SetViewCamera(str(CameraName1), 0)For this to work, one of your two camera has to already be selected in Viewport A.
Boris
Re: Switch cameras
Hirazi Blue wrote:Try this very quickly made, untested little script. Replace the strings after CameraName1 and CameraName2 with the strings for the actual names of your cameras. Create a toolbar, drag the script unto it, to make a button.
It's Python, by the way. Look out for the tabs (the lines after if and else should be indented by one tab... ;)Code: Select all
CameraName1 = "Camera" CameraName2 = "Camera1" camthis = Application.GetViewCamera(0) if str(camthis) == str(CameraName1): Application.SetViewCamera(str(CameraName2), 0) else: Application.SetViewCamera(str(CameraName1), 0)
this is what I need , Man , i love you !
