Softimage bug reporting on reddit.com
New plugins, tools etc.
Post by rray » 04 Jul 2012, 18:42
Hey folks!
I opened this "subreddit" recently as a centralized place to collect bugs and improvement wishes:
http://www.reddit.com/r/softimagebugs
Warning: Still empty at this point, also it's a bit experimental to use the reddit format for bug reporting, no idea if it will work. From its princible, it should.
Basic ideas are:
  • Works similiar to the xsibase bug thread, but uses 1 thread per bug instead of 1 post per bug.
  • There's already an Autodesk support member monitoring the list (Thanks Chris!)
  • Use the "Submit a new link" button in the bottom right to submit a bug to the list. That creates a new thread.
  • You can "upvote" bugs/wishes that you find annoying/important. This pushes them further up in the list for more exposure.
  • For a while, each new bug gets a spot high up in the list so it gets some exposure.
  • There's also a "General discussion" thread for dicussing the subreddit itself.
Consider using it! Everyone btw is welcome as a moderator there, just post something in the "I want to be a mod" thread.
Ray
