Sendin parameters to scripts through ExecuteScript
Pete
Post by Pete » 04 Jul 2012, 02:10
Hi there,
I'm just having a little difficulty sending parameters though Application.ExecuteScript to functions within the scripts.
So say I have a script called "test" that looks something like this -
function TEST(message){
	logmessage (message);
I could run it from within another script like this -
Application.ExecuteScript("test.js","JScript","hello");
But how could i send something to the message component of the test script. I've tried adding it after the fuction name but it deosnt seem to work.
Any ideas?
Thanks,
Pete
myara
Re: Sendin parameters to scripts through ExecuteScript
Post by myara » 04 Jul 2012, 02:52
http://softimage.wiki.softimage.com/sdkdocs/Application_ExecuteScript.htm
ExecuteScript ( script path, script language, function name, array of parameters )
The last "array of parameters" has to be an array. It won't work with strings even if you only need 1 parameter.
aParams = ["hello"]
ExecuteScript("c:\\test.js", "JScript","TEST", aParams);
M.Yara
Pete
Post by Pete » 04 Jul 2012, 04:03
Ahh,
I've never used an array in Softimage before :/
That makes total sense now though.
Pete
