I'm playing around with CrowdFX and found that I can't change the actors textures.
In the docs under CrowdFX "Modifying the Actor's Materials and Textures" it states that one should pick the right projection, which I did, but still nothing.
I created a new model from the default pedestrian with the noicon pic plugged into the skin cluster. This aI can see in the viewport, but when I create a crowd, the copies does not have the texture applied.
Any ideas?
CrowdFX question
Re: CrowdFX question
Not sure, but could this have something to do with the naming convention for texture projections when using CrowdFX?
Like Stephen Blair described in his blog:
http://xsisupport.wordpress.com/2012/05 ... ojections/
He even posted a short video how to circumvent this:The Crowd ICE compounds are set up to look for texture projections with the default “Texture_Coordinates_AUTO.Texture_Projection” name.
Werner
Yes that was it...or the kickstart bit when selecting the projection in the shaders that did the trick.
Thanks Hirazi and especialy Stephen Blair for the help and video.
