Runs from the script editor - out of range from hotkey/bar
bergj
Post by bergj » 07 Jun 2012, 17:15
I have a small script that will align selected verts to the last selected vert in X/Y/Z. I want to map it to f5/f6/f7.
If I run it from the script editor it works perfect. But, if I add it to the custom toolbar/hotkey I get an error message of
line 38
lastComponent = selectionLAST[0]
IndexError: list index out of range.
###Match Points X/Y/Z
##### Y
#Only works on points
if Application.Selection(0).type == "edgeSubComponent":
	Application.LogMessage("Align points works with points ONLY")
if Application.Selection(0).type == "polySubComponent":
if Application.Selection(0).type == "pntSubComponent":
	selectionALL = []
	selectionFIRST = []
	selectionLAST = []
	allTemp = Application.Selection(0).SubComponent.ComponentCollection
	for i in allTemp:
		selectionALL.append(i.Index)
	Application.Undo("")
	firstTemp = Application.Selection(0).SubComponent.ComponentCollection
	for i in firstTemp:
		selectionFIRST.append(i.Index)
	for i in selectionALL:
		if i not in selectionFIRST:
			selectionLAST.append(i)
	lastComponent = selectionLAST[0] #######################################
	##go to item mode and get the name
	Application.ActivateObjectSelTool("")
	rootObject = Application.Selection(0)
	#switch back to vert mode
	Application.ActivateVertexSelTool("")
	positionOfLastSelectedComponentY = Application.ActiveProject.ActiveScene.Root.FindChild(rootObject).ActivePrimitive.Geometry.Points(lastComponent).Position.Y
	####Works to get them to the same position
	moveALL = []
	for i in firstTemp:
		moveALL.append(i.SubComponent)
	for i in range(len(moveALL)):
		number = i
		PTtoMove = moveALL[number]
		Application.Translate(PTtoMove, 0, positionOfLastSelectedComponentY, 0, "siAbsolute", "siPivot", "siObj", "siY", "", "", "", "", "", "", "", "", "", 0, "")
	#reselect starting verts
	Application.SelectGeometryComponents(firstTemp)
Thank ye. :ymhug:
Re: Runs from the script editor - out of range from hotkey/bar
Post by xsisupport » 07 Jun 2012, 17:32
That doesn't work in the script editor either.
Your script has an Undo that undoes the selection of points, so the next line of code causes an error.
# I do this:
Application.SelectGeometryComponents("sphere.pnt[1,20-22,27-29,33-36,40-43,47-50]")
# Then run the script in the script editor...
Application.Undo("")    # Select Geometry Components
#   File "<Script Block >", line 27, in <module>
#     firstTemp = Application.Selection(0).SubComponent.ComponentCollection
# AttributeError: 'NoneType' object has no attribute 'SubComponent'
#  - [line 27]
// Steve Blair
bergj
Post by bergj » 07 Jun 2012, 20:13
xsisupport wrote:That doesn't work in the script editor either.
# I do this:
#  - [line 27]
No, while i hate to argue - you are wrong. I spent hours writing this and testing it and it does work as written in the script editor. I undo the selection back 1 point so I can find out what the last selected is by comparing two lists, selectionALL and selectionFIRST to get the single vert in selectionLAST. Thats the only way it can work. And it does work.
Here is a video showing the exact steps to reproduce the problem. Thanks in advance.
Post by rray » 07 Jun 2012, 20:48
You don't need undo to get the last selected point index. The point indices are stored in the CompentCollection in the order of selection, so doing
Application.LogMessage(allTemp[allTemp.Count-1].Index)
should give you the index of the last point that has been selected.
Your script can be shortened a lot if you use the scale command
This example is for "y", using 1,0,1 as scale values. For "x" just use 0,1,1 and for "z" 1,1,0
	pts = Application.Selection(0).SubComponent.ComponentCollection
	pt_last_pos = pts[pts.Count-1].Position
	Application.Scale("", 1, 0, 1, "siRelative", "siGlobal", "siObj", "siXYZ", "", "", "", True, pt_last_pos.X, pt_last_pos.Y, pt_last_pos.Z, 0, "")
else:
Post by rray » 07 Jun 2012, 21:10
Btw there seems to be a bug with accessing the component selection:
Typing
Application.LogMessage(Application.Selection(0).SubComponent.ComponentCollection.Count)
in the script editor and running it logs "2" when 2 points are selected. If you select another point, running the script logs "2" again instead of "3".
The ComponentCollection is being refreshed though when the selection mode is changed. So for the above script to work properly, you should do this:
	Application.SetSelFilter("Vertex")
else:
