GoZAuthor: Kostas Roukis GoZ for Softimage is a One Click Solution for 3d mesh exchange between ZBrush and
Softimage using GoZ file format.
This is the official Pixologic-approved GoZ addon for Softimage. It is developed using
the GoZ SDK and the Softimage C++ API and provides the functionality to automatically
set up a proper render tree in Softimage ready for rendering with Mental Ray. It supports
both 32 bit and 64 bit versions of Softimage on Windows.
Related plugins: GoSoftimageLite, XGoZ
local backup: GoZ For Softimage.zip
New plugins, tools etc.
Post
by Hirazi Blue » 02 May 2012, 17:42
I'm not a qualified judge as I don't use ZBrush, but this plugin by kostasph looks promising
GoZ for Softimage
Features.
1. One Click mesh exchange between ZBrush and Softimage using GoZ file format.
2. Multiple SubTools support.
3. Diffuse Map, Normal Map and Displacement Map support.
4. Render Tree with Mental Ray Material setup.
5. Complete Displacement Map setup with proper Geometry Approximation Settings.
6. Polygroups to Clusters preservation.
7. Softimage Animation (keyframed Transformations) preservation.
8. Softimage Hierarchy preservation.
More to come...
Things doesn't currently Support.
1. Softimage Geometry types other than Polymesh type are not supported.
2. Polymeshes with Ngons are not supported (Only Triangles and Quads are supported).
3. Crease /Hard Edge preservation is not supported.
4. Softimage Constrains preservation is not supported.
5. Unfreezed Softimage Transforms preservation is not supported.
6. Masking export is not supported.
Small hat-tip (in German): Danke für den Hinweis, oglu!
bottleofram
Post
by bottleofram » 02 May 2012, 18:03
Best news in a long time!
Please don't disappoint
sOBE
Post
by sOBE » 02 May 2012, 20:18
This is great, i have to test it
Clappy
Post
by Clappy » 02 May 2012, 22:25
Sweet! One glaring hole has been filled.
Post
by rray » 03 May 2012, 08:21
Thanks for the tip ;)
Anyone got in running properly? Auto install didn't work, no priviledges etc.. After installing manually, it quickly updates the model inside an open SI, but after that always starts a new instance of Softimage with an empty scene.
Clappy
Post
by Clappy » 03 May 2012, 17:42
The auto-install gave me the same error, but after manually installing the .addon everything is working as expected. No multiple instance if Softimage.
MC
bottleofram
Post
by bottleofram » 04 May 2012, 12:45
Same here. Autoinstall is being blocked no matter what. Manual goes smoothly, though.
Did just a few quick tests. Works perfectly so far!
Big, massive thanks to the author!!!
Nizar
Post
by Nizar » 05 May 2012, 08:02
Hope this will remain compatible in future release
bottleofram
Post
by bottleofram » 05 May 2012, 08:10
Nizar wrote:Hope this will remain compatible in future release
It works on 2013. I have it on good word it doesnt in those two other, lesser, packages ;)
Post
by ActionArt » 15 May 2012, 16:55
Post
by Hirazi Blue » 15 May 2012, 18:18
But as far as I can tell, "they" just made the plugin mentioned in the first post the "official" GoZ for Softimage, or am I mistaken and is this something new?
Post
by ActionArt » 15 May 2012, 19:51
Probably
At least it's official now. This is very good news for a lot of users I'd say.
I haven't heard anything about the send/get functions of Mudbox lately. I know there were some UV issues. Anybody know if those been fixed?
Post
by ActionArt » 25 May 2012, 20:19
I wonder if there's a way to get this to work with Sculptris (without having Zbrush). Anyone know?
SreckoM
- Skype: srecko.micic
Post
by SreckoM » 25 May 2012, 20:36
No, it can not. It lays on top of Zbrush API.
- H -
