toggle raycast / rectangle selection
sOBE
Post by sOBE » 30 Apr 2012, 09:36
Hi. how to create toggle shortcut on between raycast selection and rectangle selection? Thanx
Lord Futzi Voldemort
Re: toggle raycast / rectangle selection
Post by Lord Futzi Voldemort » 01 May 2012, 16:25
I think "u" is raycast polyselection, F7 is rectangle selection. You can combine the modes. They are all explained in the manual...
You can create a script, setting the desired combination of modes.
Open script editor
make your settings
select the appropriate recorded script commands
drag them onto a shelf
choose "script command" (external file)
choose the user script directory
after that ( and maybe a restart) you have a button for setting your desired mode, and in the keymap editor you´ll find a custom script you can assign a hotkey for.
Achim
sOBE
Post by sOBE » 01 May 2012, 18:21
Here is a solution
http://www.xsibase.com/forum/index.php?board=9;action=display;threadid=46816;start=0#lastPost
