So what it does it slice geometry with capping in a super fast way because of merge topo array technique. You can dive into the compound and see how it works, there's not so many nodes actually.
Accepts arrays on input. It means that we can create a procedural exploding pizza boxes simulator with use of momentum in four steps!
1) Create a box
2) Apply Slice to Pieces compound
3) Build Linear Interpolated Array and set values from (0, -3,2, 0) to (0, 3,2, 0) as the origin and normal planes, set size to 10
[rimg=500]http://xsisupport.files.wordpress.com/2012/04/agneov.png[/rimg]
4) Apply momentum deform bodies with ground and have fun playing with it!
