Test if Point is going up or down in unsimulated tree
ChrB
Post by ChrB » 19 Apr 2012, 09:48
I have some problems dealing with comparing values in nonsimulated trees.
I want to test whether a point is moving up or down. Ice tree is simple, points are moved if inside a null, based on the distance to the null. (get point position > get length of distance to null > add smt > set point position). Now I would like to compare this value to the value before i moved the null to see if the point is moving up or down, but my attempts only work in simulated trees . Any help on how to store the values for comparison?
Thanks,
Christian
Arnold for the masses!
Tekano
Re: Test if Point is going up or down in unsimulated tree
Post by Tekano » 19 Apr 2012, 12:17
oh, not sure, off the top of my head do something like store a height value for each particle but also add the current frame, then to work out on a different frame test the hieght value again but subtract the current frame - or something like that! :-
Chris_TC
Post by Chris_TC » 19 Apr 2012, 15:03
ChrB wrote:Any help on how to store the values for comparison?
Port 1: Get Point Position -> Set Data (self.YourAttribute)
Port 2: Your tree to move points based on distance
Port 3: Get Point Position and compare to self.YourAttribute
grahamef
Post by grahamef » 19 Apr 2012, 15:54
Can't you tell the direction based on the value of what you add to the point position?
