mSymm 2 : Symmetrize Tools
m|Symm2 2.0
Updated September 2014 with support for multiple objects. mSymm2 provides a number
of features for modeling with Symmetry: Symmetrize Polygon, Weights and UV with one click Realign points symmetry Select Mirror Components UV Mirroring Subtracts polygons and clusters and merges them back without losing properties.
Download page includes detailed usage instructions (Note: Top of that page is japanese/bottom is english). Introduction available on vimeo - Video of an earlier beta version.
local backup: mSymm.xsiaddon
m|Combine
Lets you quickly merge objects while respecting hierarchy and enveloping. Video introduction. Details from the si-community thread (link below):
An update to my old and simple mCombine tool. It merges, reparent, renames, matches center, copy animation, copy envelope, vertex colors, and re-paints weight colors (matching them to their bone color) [..] Custom Preference Menu: You can access this menu through the SI Preferences window, or by pressing ctrl or alt or shift and clicking in "m.Combine Polygons". It now also supports groups, layers and partitions.
You can also use it as a custom command: mCombine ( objects, tolerance, moveCenter, copyAnimation, Gator, ReColor )
Ex: mCombine ( "cube, cube1", 0.1 , true, false, true, true ). It will merge cube with cube1 with a weld tolerance of 0.1, move the center to match cube1 center, it won't copy any animation even if cube1 is animated, it will acquire cube1 properties like envelope and vertex colors through gator and it will re-color points and weight maps to match their deformers wire colors.
local backup: mCombine.xsiaddon
myara
I've been working in this plugin for a few weeks in my free time, but I just can't make it work stable.
After a lot of combinations this is the most stable version so I'm releasing it as a beta.
It may be somewhat useful and I would appreciate some feedback too.
It may still be unstable so save your scene before using it !
The script version seems to be more stable. It hasn't crashed my SI yet. So I'm also including a script version inside the Addon Folder that should be something like this:
C:\Users\myara\Autodesk\Softimage_2012\Addons\mSymm\Application\Plugins
mSymm2_script_Xneg and mSymm2_script_Xpos
They are basicaly the same with different options, one to mirror to -x and the other to +x.
Open them with an editor if you want to change something and execute it from your script editor or create a button in your main shelf. These are the most stable versions so if you have problems with the PPG and still want to use it, give these a try.
http://myara.web.fc2.com/mSymm2.html
How to execute it:
You'll find a "Symm 2.0" button in your Model / Modify / Poly.Mesh menu
Version Compatibility
v7.0 and above
Warning :
This plugins deletes half of the model, applies symmetry polygon, and then mirror weights.
Therefore, you may lose some cluster based constrains, index based shape deformers, operators, etc.
How to execute it:
v7.0 and above
Warning :
M.Yara
Re: mSymm 2 : Symmetrize Tools
Interesting. Any specific "known"/reproducible behavior that makes it crash?
myara
So far I haven't been able to isolate the problem because SI doesn't give me any error message when it crashes. In the previous "alpha" versions it used to crash SI with the 3rd or 4th click while i could run the script version 20 times without problems.
In this version it seems more stable surviving my "stress tests" (clicking it as much as possible). But still I can't guarantee 100% stability.
M.Yara
myara
I've updated the plugin (let's say beta 2), now it seems more stable even with commands (now you can undo).
I'm not 100% sure but it seems that if you use the automatic "Mirror All UVs", the probabilities that SI crashes can increment exponentially. Without "Mirror All UVs" I haven't had a single crash yet but I'll keep testing it.
M.Yara
crude
- Skype: dacrude
cool, - thanks for your effort ! Good for the next modeling session
myara
beta4 released. It seems quite stable now
M.Yara
McNistor
I'll try it soon. Right now I'm caught into some non-modeling/texturing stuff, but I'll come back with some feedback after I'll manage to do a few tests.
Edit1:
It crashed in a few mins of using. I don't know how to reproduce it yet.
If I may make a suggestion: mirroring along Z and Y could be helpful in some situations.
Edit1:
-Thucydides
-Thucydides
myara
Damn, so it still unstable...! It hasn't crashed yet here, but I'll keep testing. Was it the beta4 version?
Thanks for your feedback I really appreciate it.
I don't know If I'll ever need them but yes I was thinking in Mirror X and Y too. I'll add that too if I ever get the Mirror X function stable.
M.Yara
Nizar
Seems really nice! I will test tomorrow and give you some feedback. Thanks for sharing
myara
Thanks. In the beta 4 I was focusing only in the main symmetry tool and it was stable (I think), but there were still problems with the second tab functions. I think I got it stable and working in my beta 5 (updated 2 days ago).
There are still some minor bugs, meaning it's not working like I want sometimes but at least it isn't crashing SI.
Now I can finally start to polish the code and hopefully release a final version soon.
M.Yara
j3st3r
Sorry to say, but every second use crashes XSI (2013)...
myara
Thanks for your comment. Can you tell me which version did you try?
I'm aware that previous versions were pretty unstable but I think I got rid of the problem in the beta 5. At least I'm using it without havin a crash yet.
M.Yara
bottleofram
Hi Martin,
Just a quick question, is this nearing the final release or is there a lot more work to be done?
Sorry, im not finding too much time to have a proper look at it, so i must ask.
myara
Sorry but I really can't answer that. I think it is stable now in the beta 5 so I just need to polish the code and add some things I want, but I just don't have the time right now, I'll try to do it a few weeks later. Meanwhile I'm still testing it, using the beta5 version in my current project. If this version survives my tests and I manage to have some free time, I'll finish it ASAP.
Thanks for posting
Thanks for posting
M.Yara
myara
A new version beta 7.
I dropped beta 6, rewrote a lot of the code, add some tools and delete some other.
I decided to write the combine and separate tools as a separate addon.
mCombine & mSeparate
mSymm 2 beta7
Stable so far:
I'm still testing it, but it seems pretty stable.
I'll do some more tests, write a simple manual and if everything goes fine, finally a release.
DOWNLOAD:
https://dc616.4shared.com/download/dC2O ... m.xsiaddon
To do:
- Write a Manual.
- Select mirror components takes the original position of the components only with points.
With edges and polygons it takes the current position even if it has been deformed.
(It is in my low priority todo list)
mSymm 2 beta7
Stable so far:
DOWNLOAD:
To do:
- Write a Manual.
M.Yara
gaboraa
You have my love
thanks!
