I'm not sure but I think I've seen a post about converting particles coordinates to nulls. Whether actually someone posted something like that or not, I was wondering if there's a way to grab vertex coordinates from a pointcloud and convert them to nulls objects. At that point I could export nulls to AE to add text in post or add more stuff with Plexus.
Is this possible?
Ice coordinates to nulls? (To AE)
pdesopo
Piero Desopo
http://phoenixart.com
Re: Ice coordinates to nulls? (To AE)
Probably not exactly what you're looking for, but over at the Area there's a Python script called ICE Track Particles (login required) by Julian Johnson...
Creates Nulls which follow the position and orientation of ICE particles via a SCOP. Simply tag the relevant particles and run the script. Nulls are created at the scene root corresponding to the tagged particles.
pdesopo
Thank you Hirazi Blue,
now I'm trying to figure out how to tag particles. I'm looking on the user guide as well, but I haven't found anything so far.
Piero Desopo
Chris_TC
Particles are akin to vertices, so you tag them by pressing T and selecting them.pdesopo wrote:now I'm trying to figure out how to tag particles. I'm looking on the user guide as well, but I haven't found anything so far.
pdesopo
Thank you Chris_TC, it works fine
I just have to watch out to the number of particles to nulls as the viewport may become quite slow, but I need just a few of them.
Piero Desopo
iamVFX
Yeah, it's slow. The fastest method is to use Guil's Transform Objects by Particles command (ICE -> Kinematics/Effects), but you have to select objects for constrain and then you have to manually pick a point cloud, change index each of the nulls... It's not so fast to setup. So I rewrote command for myself: basically you need copy ConstraintToParticlesExtended.py plugin to your \Autodesk\Softimage_2012_SP1\Application\Plugins user folder and then you can select multiple clouds/meshes/curve points and run InstantiateNulls.py script to get result that you looking for.pdesopo wrote:I just have to watch out to the number of particles to nulls as the viewport may become quite slow, but I need just a few of them.
pdesopo
Thank you iamVFX.
As you said I've copied the scripts in the user folder:
\Autodesk\Softimage_2012_SP1\Application\Plugins\InstantiateNulls.py
\Autodesk\Softimage_2012_SP1\Application\Plugins\ConstraintToParticlesExtended.py
but I don't know where to look for those scripts in SI.
So, I opened the Script Editor, loaded the InstantiateNulls, selected the point cloud and then launched the script. At that point the point cloud is deselected but nothing else happens. I've tried with a curve too, but no luck. Am I doing something wrong? Sorry for these basic questions...
Piero Desopo
iamVFX
InstantiateNulls.py is a script for button, but yes, it's also can be runned through the Script Editor, and there is no need to place it into the plugins folder (unless you wanted to). It's works with selected points only. If you want to create nulls for every point in a point cloud just select them all (Ctrl + A by default) and run the scriptpdesopo wrote:Thank you iamVFX.
pdesopo
