Get new instance of a renamed object
iamVFX
Post by iamVFX » 28 Mar 2012, 15:20
Is there a way to rename an object and get it as an new instance? For example SetValue returns unicode name without parent model:
si = Application
si.NewScene()
model = si.CreateModel()
obj = si.GetPrim("Null", "", model)
print type(obj)
# <type 'instance'>
obj = si.SetValue(obj.FullName+".Name", "null_renamed")
print type(obj)
# <type 'unicode'>
# The question is: how to rename object and get as an 'instance'?
Re: Get new instance of a renamed object
Post by xsisupport » 28 Mar 2012, 16:20
According to the docs, SetValue should return the old parameter value (eg the old name) but it returns the new name. The Name parameter is a string value, so you get back a string.
Anyways...
si = Application
#si.NewScene()
print type(obj)
# <type 'instance'>
obj1 = si.Dictionary.GetObject( si.SetValue(obj.FullName+".Name", "null_renamed") )
print type(obj1)
print obj == obj1
# False
print obj.IsEqualTo(obj1)
# True
// Steve Blair
iamVFX
Post by iamVFX » 28 Mar 2012, 16:27
Oh, I get it! Thank you, Steve! Again :)
