Generate custom sample set
Pancho
Post by Pancho » 17 Mar 2012, 09:37
I'm a bit lost here.
While the "Generate Sample Set" node only emits once (if you set it up like this) I seem to miss the point of how I'm able to do this with the "Add point" node by itself.
How do I set up a particle emitter which uses custom input (point location), but emits only once at the start frame and then not any more?
Thomas
Re: Generate custom sample set
Post by EricTRocks » 17 Mar 2012, 10:15
Get a Current Frame node and an if node. Plug the Add Point node into the True port.
Eric Thivierge
Pancho
Post by Pancho » 17 Mar 2012, 12:20
That's something I tried. But I didn't succeed with frame 0, only with frame one and above. Can't I emit on frame 0 or did I set something up in the wrong way?
Post by Hirazi Blue » 17 Mar 2012, 12:36
Are you trying this on a simulated ICE Tree? If so, you could try "Execute Once"...
And yes I think emitting in a simulated tree normally starts at frame 1, but I'm not 100% sure.
edit: from the docs...
Note that ICE particles are actually emitted only starting the second frame of the simulation frame range.
(Quoted from here)
Post by EricTRocks » 17 Mar 2012, 12:47
Frame calculations start on the first frame it can calculate stuff for which is not frame 0. If you want frame 0 then you need to set your simulation environment to start at -1.
Eric Thivierge
Pancho
Post by Pancho » 17 Mar 2012, 12:59
Thanks guys!!!
Yes, simulated ice tree.
Mr.Core
Skype: giga-core
Post by Mr.Core » 17 Mar 2012, 13:31
Build a simple trigger. By default all custom attributes inits with 0 ( identity in case of matrices ), so you can use it and execute anything independently of your first frame value
Post by EricTRocks » 18 Mar 2012, 00:22
Great tip!
Eric Thivierge
iamVFX
Post by iamVFX » 18 Mar 2012, 13:33
As an option
Pancho
Post by Pancho » 18 Mar 2012, 13:39
Very cool!
