Inside a compound I do have several get data nodes which are supposed to share the same reference name. Unfortunately a pass through node connected to "expose input" doesn't work here. Is there a way to achive this without connecting each get data to its own "expose input"?
Thomas
Pass through reference
Re: Pass through reference
Have one Get Data that exposes the reference.
Then take the Out Name from that, and plug it into more Get Data nodes.
Pancho
Unfortunately not working entirely. In some cases the source is "self", in others "self.pointNeighbors". In each case I need the same custom attribute. If Icould just share the same reference input, no problem, but this way it doesn't work.
grahamef
I'm not sure why that's a problem. You expose the reference and in name of one Get Data node, and use its out name wherever you need it. You also plug its out name into a second Get Data to get "PointNeighbors", and use that wherever you need it.
Alternatively, you can restrict your compound to work only on "self", and not expose anything at all. Problem solved.
Pancho
THanks for trying to help out so far, but I didn't succeed yet. So here's a picture of the problem. Probably that helps. But maybe I just don't get it. : )
Pancho
Thanks! But it's the colorDirectionFromCurve attribute which I want to pass into the compound only once. It's the two references I'd like to combine.
I use this compound to blur vertex map values. So "self" and "self.pointneighbor" will be the constant path, but the attribute changes. Currenly I need to type in twice the name of it and that's what I'd like to make easier by only have one reference.
Thanks anyway!
Thanks anyway!
caledonian_tartan
unfortunately there's no "String to Reference" Node. it would work involving the "Concatenate String" Node...
hmm...
as far as i know we should now be able to program our own new ice nodes... (are they called custom ice nodes?)
shouldn't be hard to get a "String to Reference"...
i try
edit: here's what i found in the SDK docs: "Reference. Note: this data type is not available for Custom ICENodes."
anyway. i tried the ICENodeWizard and created a new ICE Node. as Reference is not supported i wanted to let it undefined (black) and see what happens.
BUT. i'm not able to compile it.
hmm...
i try
SI 2015 @ WIN7-64
