I know that I would like to write a script for that, e.g. record a script for this purpose. But the point I need to figure out is how to avoid the direct naming of the object. It would need to be something like "current.object" or "selected. object" like in ICE self.
Can somebody please point out the right "vocabulary", "grammar" and probably a reference site/book/pdf for this stuff?
THomas
Applying several maps to multiple objects
caledonian_tartan
Re: Applying several maps to multiple objects
in VB script it is:
GetValue( "SelectionList" )
SI 2015 @ WIN7-64
Pancho
I'll give it a try! Thanks!
myara
If you're going to use VBS, you'll need to use Set to get an object. Otherwise you'll get only a string.
But, even if you use Set for that, you will get an Object Collection. So if you have multiple objects selected you may have an error in your process.
I ussually use:
'VBS
dim oObj : set oObj = selection(0)
//JScript
var oObj = selection(0)
But if you do something that changes your selection in your script, this variable will be automatically updated. So if you want to retain the first select object you'll need something like this:
'VBScript
dim oObj : set oObj = getvalue(selection(0))
//JScript
var oObj = getvalue(selection(0))
If you do:
'VBScript
set oObj = getvalue("selectionlist")
you'll have to specify the object index like this:
oObj(0)
this will get you the first selected object.
I ussually use:
'VBS
//JScript
'VBScript
//JScript
If you do:
'VBScript
oObj(0)
M.Yara
