I'm setting up a UV pass, following the advice in this thread (look for last post).
However, for some reason I'm getting this:
As you can see in the node's preview it should range green to red but instead it's blue to magenta. Any ideas on why and on how to fix?
thanks,
Jasper
projection lookup question
druitre
druitre
Re: projection lookup question
Hi again, I found a way to fix it - still not clear on why the wrong colors, maybe it's a bug?
Anyway, what I did was insert a vector-vector node and fiddle about with parameters until I struck gold. (see image)
Just thought I'd post it in case anyone else comes across the same problem.
