Remove Play Backward button
iamVFX
Post by iamVFX » 12 Feb 2012, 20:59
It causes a crash when I'm working with some complex simulations, I often accidentally click on it, how to make that it did not do anything? Thanks!
Re: Remove Play Backward button
Post by Hirazi Blue » 12 Feb 2012, 21:25
You could build your own "playback panel" toolbar with only the buttons you need and use that instead of the one embedded in the layout, which you could even delete from your layout altogether by editing the layout. But there must be a simpler way, I just don't see it ATM.
iamVFX
Post by iamVFX » 12 Feb 2012, 21:37
Good idea! But I've already figured out how to stop playing with the help of EndCommand_OnEvent command :)
