Shell scripts
Shell ScriptsAuthor: Constantine Tarasenkov
Some alternatives to the classic thickness plugins that work for special cases like irregular polygons. For usage details and downloads, see the si-community thread linked below.
local backup: shellscripts.zip
iamVFX
Shell scripts
Post by iamVFX » 04 Feb 2012, 10:37
I had a gear base mesh (that was made with help of EssentialGeo plugin :-bd ) that I want to extrude with capped bottom and preserved UV.
Result of Apply Thickness and AI Thickness compounds does not makes me happy, so I wrote a simple script that duplicate and inverts polygons of the object, merges two object together, hides original meshes and shows extrude and merge property pages
iamVFX
Re: Extrude script
Post by iamVFX » 04 Feb 2012, 11:20
Push version
iamVFX
Re: Extrude script
Post by iamVFX » 04 Feb 2012, 12:05
MoveNormal version
Re: Extrude script
Post by origin » 04 Feb 2012, 13:23
that's not a bug of movenormal but expected behavior when moving weird polygons along normals
anyway, I use this plugin for ages, I think it does same thing as your plugin
http://artifacts.sakura.ne.jp/sakanaya/ ... _thick.htm
iamVFX
Re: Shell scripts
Post by iamVFX » 04 Feb 2012, 13:48
origin wrote:anyway, I use this plugin for ages, I think it does same thing as your plugin
Yes, it's doing the same thing that my Push script do, but Weld Edges op that Interactive Thickness use doesn't always work for me.
I'm curious why Move Normal do this weird stuff. Push and standard extrude scale works great for hollow cube from the video
(Moderator edit: after you renamed the thread, I renamed this last post also, that way all the next posts will have the new title and while the thread title shows up in the "Active Topics", the post title of the last post shows up on the "Index" page - HB)
iamVFX
Re: Shell scripts
Post by iamVFX » 18 Feb 2012, 12:42
A script that extract extruded polygons to another object. Should I parent them?
http://www.youtube.com/watch?v=ApsJcQD6TS8&hd=1
