3ds max Radius Influence FX
Hey guys, happened to watch this video today and i was wondering how hard it would be to create something like this in ICE.
i gave a shot mostly on disconnecting edges/polygons and applying some force but then i got stuck, this seem a really awesome script, wonder if we can have a discussion and share some ideas on how to achieve those deformations on a geometry.
cheers, Max
cheers, Max
TwinSnakes007
Re: 3ds max Radius Influence FX
Yeah, that's some pretty basic stuff he's doing there. We could wire that up in ICE without any coding and it'd be multi-threaded and wouldnt need any pre-processing like he's doing either...and best of all....FREE!
To do the transform tricks he does, off the top of my head, we'd need:
TestInsideNull
GetDistanceBetween
RandomizeAroundValue
DisconnectComponent
I wouldnt use Forces for the simple stuff he's doing. We can take his concept WAY further by introducing Forces, but not for the simple transform stuff he's showing in that video.
TestInsideNull
GetDistanceBetween
DisconnectComponent
Chris_TC
I agree. He's not using forces in the video, just some kind of scaling and rotation based on a distance to the input sphere.
You can use forces if you make a point cloud, generate one particle per polygon and then have the topo tree read the particle data. But I'd start with the basics and make a regular non-simulated topo tree.
This may get you started if you haven't watched it yet.
TwinSnakes007
Chris, maybe you can give me a headstart on something and save me some research time.
The manual says you can animate the modelling region of one object using a custom parameter from the simulation region of another object. Basically, an animated modelling region.
I havent had a chance to wire this up, but was wondering if you or anyone else has?
That particular feature would help out alot for this effort.
iamVFX
I made this compound one day, it's slow (because I've used repeat node, yes, shame on me) and it's working in the per point context, but it works within an one node. If you want to modulate polys by null and have more speed you better use Guil's script
Chris_TC
Yes, I have tried it and it works.TwinSnakes007 wrote:The manual says you can animate the modelling region of one object using a custom parameter from the simulation region of another object. Basically, an animated modelling region.
You just read the attribute from your simulated ICE tree and use it somewhere in your topo tree. If you want to use per-point data from a point cloud, you have to Build Array From Set, or the topo tree will refuse to read the attribute.
For example, if you have one particle per polygon, you might simulate an attribute called MySize. You store it as an array on the point cloud and read it on your topo tree via Select in Array (supplying the polygon index).
guillaume
Please don't use those old compounds from my blogiamVFX wrote:....If you want to modulate polys by null and have more speed you better use Guil's script
Cheers,
Guillaume Laforge
My main problem is how to apply forces after you disconnect the components in a non-simulated ice tree environment. I wouldnt want to use particles to drive the deformations, but more like some effectors and easy to control deformers/forces.
After i disconnect all the polygons/vertex i'm stuck into not bein able to move the polygons with some forces..
bare with me i'm no ICE expert.
thanks everyone for answers
Max
Max
TwinSnakes007
The one thing I'm a little grey on is - how to dynamically set the visibility on a per polygon basis in ICE? Is that even possible? An alternative would be to use DeletePolygon, but a Topo change seems expensive.
Chris_TC
Scale it to 0. Or you could apply material IDs with ICE, as this works per polygon.TwinSnakes007 wrote:The one thing I'm a little grey on is - how to dynamically set the visibility on a per polygon basis in ICE? Is that even possible?
TwinSnakes007
Made some progress on this....will post some stuff this evening after work.
OT: Man I wish I could play with ICE over the web so I could tinker with it while I'm at work.
TwinSnakes007
Here's a simple start....
* Particle Grid with Particles Shape set to Box
* Modelling Region ICE Tree so it's all "live".
Next is to add the ability to set the Scaling/Rotation/Translation Min/Max.
druitre
Hello Twinsnakes,
how difficult would it be to have the transforms etc be driven by an arbitrary shape? An 'inside mesh' type of controller for instance, a weightmap or an input image (luminance etc). In my opninion that would expand the possibilities a lot.
Jasper
Jasper
just wow, especially for the easy use..
