Is it possible to nest a secondary shape ice tree in to a simulated ice try by weight map? I am trying to control shape deformation through my animated weight map.
Thank you!
nesting ice trees
gustavoeb
- Skype: gustavoboehs
Re: nesting ice trees
I dont understad exactly the question. It is not possible to nest one ICE tree inside another, since they are separate operators...
That said if you want to change inbetween two shapes (however you store them) you can use a Linear Interpolate node and you can plug the weightmap as your blend parameter.
Was that of any help?
Gustavo Eggert Boehs
