Per poly to per point
Victorcg
Post by Victorcg » 21 Jan 2012, 21:43
Hello.
I need to transfer custom attribute from polys to corresponding vertices. How can I do it?
Thank You.
Chris_TC
Re: Per poly to per point
Post by Chris_TC » 21 Jan 2012, 22:51
A vertex typically belongs to several polygons. Which one should it inherit the value from?
Get Data self.VertextoPolygons returns an array of all polygon indices the vertex belongs to. If you build an array from your per-polygon data set, you can select the relevant index in it.
