CiaranM wrote:I'm not certain, but I have a funny feeling that Mentalray does not support moblur on animated displacements.
Just tried it and it looks like you are right.
I used ICE for deformation. I made a turbulize distort that loops several times each frame but I cant get motion blur to look like on this video. I get blurred pixels where there is a motion and cant get look like on video where it looks like phases from distort motion are just alpha blended with several layers. What I did then is slowed animation 5 times, made the distortion animation to loop every 5th frame, and put rendered images in after effects, time remapped the sequence to go 5 times faster and turned on frame blending. That way I got look like on the video. But problem with doing it like this is that it is impossible to change something later (animation for example). It could be possible done with several render passes with different distort value on each pass and put that together in composite software, but that is also not a very good solution because render time would be lot longer.
Has someone here managed to get something like this in softimage?
